(1 March 2021) We take a look at small boat rudders. The 15 March issue has more rudders.
...an update from my blueprint paper supplier, Freedom Paper in Houston, is that they were unable to locate any coating material for Diazit process blueprinting. Not in the US or Asia. So it is kaput, no chance. Looking deeper into getting scans of my mylar tracings. Chuck L sent a tally of last years sales and we figure if we scan the the top twenty or so that will cover most of the income. I am still hunkered down due to the virus and I think getting scans will take a lot of leg work around here, including getting trials to assure quality. When done, you will be able to order those downloads. So the plan now is to eventually continue the catalog on a pdf download basis, no more blueprints through the mail unless Chuck wants to take that on as an option. Right now you can download files for Jonsboat and Toto from Duckworks. These are not scans of my originals but rather are cad works done by kind and interested customers.
...AS FOR REND LAKE MESSABOUT 2021, I think it is still very much wait and see for COVID. Right now the infection rate for this county is running about 350 new cases a week, down from 1400 new cases a week in November and December. This compares to about 150 per week for last June so it is currently still much higher. Mass vaccine operations have started here but then again the bars and restaurants have reopened which has always been bad here. Anyway, if it happens, as always the messabout would be the weekend before Father's Day, June 11 and 12 this year. I will update as things go along.
Paul Moffitt's finished their kneework and got to building. Voila! Two fine Rio Grandes! Hope Paul sends an in the water with smiling faces photo when that time comes.
SMALL BOAT RUDDERS
small rudder
RUDDER BLADE...
SINK WEIGHT...
small rudder
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
cary hinges
AF4Breve
AF4Breve, POWER CUDDY SKIFF, 15.5' X 5', 350 POUNDS EMPTY
Bruce Given of Virginia Beach, Virginia, did a perfect job on the AF4B prototype shown above. He said he didn't have the shop space to build the 18' AF4 and when I saw the photo of him working I believed him. So I scrunched the 18' AF4 down to 15.5'. I took 1' out of the cabin shortening it to 7', 1' out of the cockpit shortening it to 5', and 6" out of the motor well. I'm pretty sure everything is still acceptable, although the longer AF4 might still be preferred if you can live with the length. The width and depth of the cabin and transom are tha same as AF4's.
To a certain extent you could build the shorter boat without new plans by scrunching up the length dimensions. That method would be a lot more reliable for a simple flat iron skiff like this one. For more complex shapes where all the panels are expansions, including sides, bottom and bilge panels, it would not be so reliable. Bill Wainright built the original Smoar rowboat by scrunching up the Roar2 drawings but he is a sculptor and did the job with a model. Later I drew Smoar from scratch. Also the bevels shown on the long boat drawings will not be correct. That might be no problem with a taped seam hull.
af4b
So AF4B is a totally new set of drawings. There are two changes made besides the scrunching. I made the bottom 1/2" thick instead of 3/8" as I built into my AF4. Most folks would prefer the extra stiffness. On AF4 I think of the bottom flexing only when running hard into chop. The extra thickness finds its way into a lot of other parts since they are made from the off fall of the bottom panels. You could make the bottom from 3/8" ply and save about 50 pounds on the total weight. The second change adds a bottom to the bow well which lifts the well bottom up about 18". It is more complex to build but the original deeper well is hard to reach all the way into. The area below the new well is accessible from the cabin for an iota more storage.
Still suggesting 10 horse power max.
AF4b
AF4B is simple nail and glue construction with four sheets of 1/4" plywood and four sheets of 1/2" plywood.
Plans for AF4B are $30.
1aug20, Prop Slip, Oracle
1feb21, Bulkhead Bevels, Toto
15feb21, Trailering, IMB
