(15 February 2021) We take a look at trailering. The 1 March issue will review rudders.
...an update from my blueprint paper supplier, Freedom Paper in Houston, is that they were unable to locate any coating material for Diazit process blueprinting. Not in the US or Asia. So it is kaput, no chance. Looking deeper into getting scans of my mylar tracings. Chuck L sent a tally of last years sales and we figure if we scan the the top twenty or so that will cover most of the income. I am still hunkered down due to the virus and don't see it going away soon, but I think getting scans will take a lot of leg work around here, including getting trials to assure quality. When done, you will be able to order those downloads. So the plan now is to eventually continue the catalog. Right now you can download files for Jonsboat and Toto from Duckworks. These are not scans of my originals but rather are cad works done by kind and interested customers.
...AS FOR REND LAKE MESSABOUT 2021, I think it is still very much wait and see for COVID. Right now the infection rate for this county is running about 400 new cases a week, down from 1400 new cases a week in November and December. But this compares to about 150 per week for last June so it is currently still much higher. Mass vaccine operations have started here but then again the bars and restaurants have reopened which has always been bad here. Anyway, if it happens, as always the messabout would be the weekend before Father's Day, June 11 and 12 this year. I will update as things go along.
Paul Moffitt's students are getting on their knees for an interesting project. (Gee, all we got to make in high school was a shoe box.)
TRAILERING PLYWOOD BOATS
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
...LIGHTS...
...FINALLY.....
IMB
IMB plans are $30.
1aug20, Prop Slip, Oracle
1feb21, Bulkhead Bevels, Toto
