(15 October 2018) We look at small boat rudders. The 1 November issue will make some sink weights.
A new Harmonica started in Texas.
SMALL BOAT RUDDERS
small rudder
RUDDER BLADE...
SINK WEIGHT...
small rudder
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
cary hinges
Jonsboat
Jonsboat
jonsboat
Jonsboat
Plans for Jonsboat are $25.
1jan18, Trailering, Normsboat
1feb18, Bulkhead Bevels, Toto
15feb18, Sail Rig Spars, IMB
