(1March2013) This issue will continue the old "drawing a boat" essays that first ran in 2005, in particular the preliminary displacement calculations. The 15 March issue will continue the topic.
Walter Platzer teases us every winter's end with photos like this. Here he is off in his Mixer on a 4 day beachcruise of Thailand's Koh Chang Island. We ran his article about this special sail rig a while back.
FIGURING DISPLACEMENT
THE VERY BASICS...
One of the real basic errors in boat design is to not match the capacity of the hull to the weight it needs to carry. It's actually pretty easily done. Let's take an example: a fellow wants a 12' skiff to handle two adults. He figures the empty boat will weigh 120 pounds and the adults together at 350 pounds. So he has to float a total weight of 470 pounds.
One thing is for sure: no matter what the shape of the hull, it will sink into the water until it pushes aside, or displaces, 470 pounds of water. (The way I heard it was that ancient Greek mathematician Archimedes figured out the basics while sitting in the bath tub.) Fresh water weighs about 62 pounds per cubic foot and salt water usually about 65 pounds per cubic foot. So the volume of fresh water displaced by the 470 pound boat is 470/62 = 7.6 cubic feet. That was easy!
We talked about the prismatic coefficent a long time ago and you should be able to look it up in the way back issues index. Basically we construct a prism with the same length as the waterline length and the same cross section as that of the boat's maximum beam. The hull will fit neatly into the prism. Divide the volume of the underwater hull by the volume of that prism and you have the prismatic coefficient.
jewelbox
Toto
Remember that the prism has the same length as the hull's waterline length and underwater cross section as the boat's maximum cross section. Remember we want a 12' boat, but the waterline will be shorter if we want some rake to the ends (for looks) and maybe enough rocker to make sure the stem and stern don't drag the water (for low drag). We might guess that the waterline length will really be about 10'. Then the maximum cross section would have to have 13.8/10 = 1.38 square feet of area below the waterline. If we wanted a flat bottom 3' wide (wide enough to have sailing stability and narrow enough for reasonable rowing) we would have a draft of approximately 1.38/3 = .46' or 5.5".
hull1
hull2
METHOD 2: THE CURVE OF AREAS...
This method of the "curve of areas" is an accurate and flexible way of determining the volume of almost any oddly shaped thing. It's actually pretty easy to do but first you need a drawing of the proposed boat (unlike the prismatic coefficient which just needs a general idea of the boat).
sections1
sections2
Next we graph those underwater areas spacing them the same distance apart as they are on the real hull to get the "curve of areas" like this:
curve of areas
The area enclosed under the curve of areas is a volume and is indeed the volume of the underwater hull - it's what we are looking for. In the old days you would measure the areas with a planimeter, a clever and expensive gadget. But you can do well by just breaking down the curve into triangles and trapezoids, figuring the area in each trapezoid, and adding them all up. In the example, second trapezoid from the left is figured by 1/2(175+209)X12 = 2304. Adding the sections together gives us a total of 12500 at 5.5" draft. That equates to 450 pounds of water. So the first guess was off by 20 pounds or about 4%. By the way, the drawing showed a waterline length of 9'5" instead of the first guess 10'.
THE COMPUTER METHOD...
We'll apply this to the new Bobsboat design.
Paddleplank
PADDLEPLANK, PADDLE BOARD, 14' X 32", 70 POUNDS EMPTY
Can you walk this plank? Actually the request was for a stand up paddle board, sort of like a surf board that is paddled while you stand up like on a real surf board shooting the big waves in Hawaii.
I had all sorts of reasons for not designing it, the first being that I could never stand up on such a thing myself for more than a second or two. As a starting point I decided to take the bottom of a light dory, which is usually about this length and about 2' wide. It is generally held that you should never stand up in a light dory and my experiences confirm that. But it looks like the surfers are well ahead of us mortals in that respect and besides they expect to get dumped regularly and maybe the long double paddle offers a bit of stability, sort of like the poles the tightrope walkers use.
So I started with that bottom and added a little top, maybe 4" of freeboard which will not keep you very dry. I put just enough rocker to support 470 pounds before the bow and stern start dragging, enough for two people plus the weight of the hull usually. I can't see two people standing up on this at once but if they both sit it might be a fun wet boat for warm waters. The deck is supposed to be totally watertight, of course, so it will shed water like a duck and be low enough in the water for a swimmer to reboard.
I knew from the start it would not be light, at least not light enough to carry under one arm as they did in "The Endless Summer". Bolger had warned all of us long ago that decks weigh a lot, more than the bottom he said because they must be strong enough to take your weight with no water underneath pushing upward. So Paddleplank will indeed weigh about the same as a light dory. I figure 75 pounds if made with the usual 1/4" plywood, maybe 15 pounds lighter if the topsides are made with 1/8" ply. You can't really go thinner than 1/4" on the bottom and you need some thicker area where you stand, so it is hard to make it much lighter.
I wondered a bit about how Bruce Brown carried his surfboard around under one arm. Sure, he's a big hunk but even so there were expensive tricks involved. Let's say you need to float a 180 pound man on a board. Light wood weighs over 20 pounds per cubic foot, so if you totally immerse a cubic foot of that wood it will have about 40 pounds extra buoyancy, given that water weighs about 60 something pounds per cubic foot depending on where it is from. So you would need about 5 cubic feet of wood to float the man, or at least 100 pounds of solid wood. But then he would be just awash, so to give an inch or two of freeboard to go surfing would require even more. I suppose that is the situation with old time historic surfboards.
I googled around some surfboard history. The first hollow boards were made about 90 years ago and they first broke the 100 pound barrier, so my guess was pretty close. Then they went to balsa cored boards (Hey! Balsa is really a hardwood!) and got down to 60 pounds or so. Then post WW2 they went to fiberglass and foam, etc.
Anyway, after the google, I stopped feeling guilty about the weight of Paddleplank.
I'm thinking Paddleplank is too wide for a real surfer dude but would be a good plaything for the rest of us.
Three sheets of 1/4" plywood with the chines done with taped seams. I have it drawn for jigless construction but you might not get away with that since the sides will be so thin and limber. Thus I have also shown some dimensions to a "base line" so you could set up the initial construction on a ladder frame to hold it all true until the bottom is on.
Prototype Paddleplank plans are $20.
