(1 November 2012) This issue will review capsize lessons learned at Sail OK. The 15 November issue will continue the sail sizing essay.
After Sail OK Kathy and Chris cruised the Arkansas River in full autumness.
Capsize Lessons
RICHARD WOODS...
TO START WITH...
THEN...
ONCE THE BOAT IS RIGHTED...
ANYWAY...
THE DEMONSTRATION...
THEN THEY DID IT AGAIN...
Piccup Pram
Piccup Pram
Donovan's
Vince's
Hudson's
Jim's
Reed's
Here is another by Doug Bell:
This one is by Jim Islip:
And this one by Ty Homer:
