(15April2012) This issue will cover rowing gear. The 1 May issue will review electric boat propulsion.
On a quiet beach on the Florida Gulf Coast two cuddy cabin boats get ready to sail. Closest is Tim Gosnell's Toon2 and afar is Gary Blankenship's veteran Frolic2.
ROWBOAT SETUP
Perhaps just as good as a cleat is the arrangement that Rob Rhode-Szudy made for his Piccup Pram with a rope loop to the seat that captures a bracing bar that rests on the floor of the boat:
TOON2
toon2
The sail rig is the same 96 square foot sharpie sprit that I used on Pencilbox and AF3. It started as the main on my old Bolger Jinni from 30 years ago. Very easy to make and use and efficient if you can live with a 21' mast on a 15' boat.
As I am writing this there are two Toon2s afloat that I know about. Both were recently launched. This one by John Wolf in Texas..
...was made with the blueprint sharpie sprit rig. He says it sails fine.
And this Toon2 by Tim Gosnell in Florida has a balanced lug sail adapted from the AF3 lug sail plans...
This Toon2 is also said to be a fine sailor. Compared to the stock sharpie sprit sail I would expect it to sail not so close to the wind. On the other hand it will certainly be easier to tow and set up and easier to reef and maybe be as good or better on the other points of sail. It's all the usual tradeoff. Note that it is not really a large boat and that the weight of the skipper in the stern affects the trim quite a bit. So with fine tuning she will be faster and better all around with the weight more forward. Then again, for lazing around on a slow day I found with my Piccup Pram that trim was not that critical and if the skipper lounged comfortably against the aft bulkhead, it looked bad but it sailed good. On its maiden voyage Mark's Toon2 was cruising all well with a Frolic2 and a Wooboto.
Plans for Toon2 are $40.
