(1May2011)This issue is about small boat rudders. The 15 may issue will start a short series on how I take a stab at determining sail area.
THE REND LAKE MESSABOUT WILL TAKE PLACE ON JUNE 10 and 11 AT THE PINTAIL LOOP OF THE NORTH SANDUSKY CAMP GROUND AT REND LAKE IN SOUTHERN ILLINOIS. USUALLY THE SANDUSKY CAMP GROUNDS MIGHT BE FULL FOR THAT WEEKEND. BUT SOME OF OUR BOATERS HAVE RESERVED SOME OF THE SITES THEIR SO YOU (AND I) MIGHT PASS THAT WAY FIRST SINCE SEVERAL TENTERS CAN SHARE A CAMPSITE. IF NOT, THEN I WOULD TRY THE WAYNE FITZGERRELL STATE CAMPGROUND WHICH IS ON THE MAIN CAUSEWAY LEADING TO SANDUSKY. THEIR WEBSITE SAYS IT IS STRICTLY FIRST COME FIRST SERVE, NO RESERVATIONS ALLOWED. IT IS A VERY QUICK DRIVE FROM THERE TO SANDUSKY. HOPE TO SEE YOU THERE!
Tristan Gosnell learns to sail with his dad's new Toon2. This picture is clipped from a great U Tube video he put together which you can view at http://www.youtube.com/watch?v=oCIyyH3nutQ
SMALL BOAT RUDDERS
GENERAL...
I have no rule that I use to size a rudder. I just draw something that looks like the proper size for the boat. I always make it shorter than the leeboard with the idea that the leeboard will bump the bottom first, you will notice that and prepare for shallow water or underwater objects with unlashing the main sheet and having a firm hand on the tiller. But the question arises, "How much rudder do you need?"
I think the worst condition the rudder will usually see is when running downwind with the sail boomed way out like this:
There might be conditions of imbalance during close wind sailing when the rudder will be overpowered but not if you have done your "sail area math". So what have we in the above picture? The sail is boomed out all the way and its force is pulling straight ahead but many feet off to the side. The hull has a drag equal to the sail's force and the boat has reached its terminal velocity so to speak. The distance between the sail force and the drag creates a torque that the rudder and leeboard must balance. I suppose on an old square rigged boat the sails would still be on centerline and this condition hardly occurs and you might hardly need a rudder running downwind. Perhaps the worst case would be the old catboats with huge booms, short hulls and very shallow rudders.
In the sailing I have done with my own boats the only case of ever running out of rudder came under this downwind condition with the original WeeVee. It had a gaff sail, was only 7' long, and I was trying a shallow end plated rudder. In a brisk downwind no amount of rudder deflection would hold it on course, it would swing around and round up into the wind. I found I could "tack" it downwind by sailing a broad reach instead of running straight downwind. I tried various sizes of endplates but finally went to a deeper conventional swing rudder as shown in this article. That cured it! I gave up on shallow rudders.
I think Chris Feller has suggested the rudder on Mixer (and later his Philsboat, too) was too small. Maybe so but the clear answer on how to fix such a situation is simply to make the rudder bigger, deeper in particular since deeper is in general more effective than wider. Almost any rudder I've ever designed was something that hung on the stern transom so changing it is pretty easy, unlike say a rudder that is mounted to a shaft that runs through the hull. Anyway I wanted to point these things out before getting into the meat of this older article.
RUDDER BLADE...
SINK WEIGHT...
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
Blobster
Great job, Miles!
Plans for Blobster are $45.
